Exhaust port corrosion
BernieS
Post by BernieS »
I was doing some exhaust work on my C-145 and discovered some mild corrosion around a few exhaust ports where exhaust gases had been leaking past the gasket at the port. Does anyone recommend any type of sealer to add when I install the new gaskets? Also, what brand of gasket do you all prefer?
Many thanks,
Bernie
Re: Exhaust port corrosion
By port I assume you meant at the cylinder head. I would only use "No Blow" style TCM PN 627429 or equivalent after market makes no difference, buy the least expensive.
https://www.aircraftspruce.com/catalog/ ... -11230.php
Note: You will have to custom fit each to it's cylinder by grinding some metal away for clearance to the next head or intake. Some need it others won't. These are reusable and last a long time.
You don't use any sealer of any sort. Slip joints get anti-seize compound.
cessnut
Post by cessnut »
A fairly common misconception is that installing a spiral wound gasket will magically solve exhaust leaks. If the exhaust port or the riser flange are not perfectly clean and level, a no blo gasket will not seal. It is also a good idea to evaluate the health of the studs while the exhaust is removed. Do not use sealant. Obtain a copy of M-0 and follow it.
Bernie, Welcome to the 170 Assc’n Forums.
The good news is you’ve found the source/reason for the exhaust leak.
The bad news is…. if the cylinder exhaust flange is eroded…. it must be re-surfaced before the leak can be stopped. Gaskets and sealants will not stop a leak caused by eroded cylinder exhaust surfaces.
There is a history to the methods used to resurface that area on a cylinder…. Back when cylinder rebuilding was a profitable business.. cylinders were often removed and the area built-up by welding, then machined flat again. This was usually done in conjunction with grinding cyls oversize or channel-chrome/plating to renew the I.D. back to standard. These processes are not often performed since new cylinders became popularly supplied by aftermarket companies like Superior, E.C.I., and others. By the time those processes are completed the difference in price from new cylinders made complete replacement more popular. Here’s an Aviation Consumer article on the subject:
https://www.aviationconsumer.com/aircra ... -worth-it/
There aren’t many folks who will do cylinder overhauls, but if you wish to pursue it you might contact Gibson or Corona:
https://gibsonaviationok.com/cylinder-overhaul
or
https://www.coronaengines.com/Cylinder-Overhaul
Hope this helps.
Has anyone used the exhaust port resurfacing tool that Aircraft Spruce markets here? Although Spruce says it's available, the adapter plate for the Continental doesn't show up on their website. The tool is made by Sydow Tool Engineering Corp. The adapter is available on their website for $200.
Exhaust Port Surfacer.png (82.3 KiB) Viewed 1888 times
