Wiring Diagram for 48?
I’ve looked around the forum and maybe I’ve missed it. Does anyone have a good wiring diagram for the 48’ firewall forward (FWF)? Thanks in advance!
Re: Wiring Diagram for 48?
The best there is for a 48 is found in figure 23 of the IPC. Not much better is that for an A model also found in the IPC. The A was wired the same so if you can't make it out on the 48 IPC look at the A model IPC. The 52 B model is also the same for the most part and by the time they got to the B model IPC they got a little better at presenting it.
