It appears my Turn and Slip needle broke
mmcmillan2
Post by mmcmillan2 »
Ever seen this? Installed 100 hrs and two years ago.
mit
Re: It appears my Turn and Slip needle broke
Post by mit »
Well at least the ball still works! 8O 8O
I think you need a little-bit more right aileron...
mmcmillan2
Yea, all I use is the ball typically. Look at that little screw sitting in the bottom, looks like it’s a simple fix. I’m sending it to Century Instrument Corp., hoping they give me a cheap rate if it is a quick fix. It would be real cool to swap it with an RC Allen attitude indicator with Rate and Ball, but that’s $2500.
