Center stack
54170b
Center stack
Post by 54170b »
Im going the route of putting a center stack panel in my 170, I can't find many pictures and I'm trying to come up with a good design so if you have any photos of your center stack panel could you please post them here? Thanks :D
ptporebski
Re: Center stack
Post by ptporebski »
Hello,
That is a not insignificant undertaking as You will need to convert the "T" yoke to a "U" yoke (you probably already know that). Avion Research in CA sells a superb STC to do this. I too am interested in doing this at some point in the future.
Regards,
Pete Porebski
N4126F, 1959 C-172
N4126P, 1976 C-177B
N426JP, 2015? Falco F8.l
The better is the enemy of the good.
1959 C-172
Re: Center stack
While you guys are at it making these things look "modern"... why doncha' convert 'em to tricycles, slanted tails, and install air conditioners..? :twisted:
(just kiddin' around) :lol:
54170b
Re: Center stack
Post by 54170b »
Del air has an stc for 2,713, much more affordable, and has been much more pleasant to deal with than avion. According to Avion, they no longer offer a complete center stack mod for the 170.
Re: Center stack
If you're going to install a later model "U"yoke to replace the "T" yoke, make sure the new yoke has the same length from the pivot point bolt hole to the bottom cable connecting bolt hole. I had to alter the one I used. If there is a difference, it will change the control throw. I think it probably concerns the Cessna model yoke used as a replacement. I had to shorten the throw on the one I had.
54170b
Re: Center stack
Post by 54170b »
He is going to modify mine so I don't think this will be a problem, but thanks
shortfielder
Re: Center stack
Post by shortfielder »
Yes, not all U yokes are the same. I bought one from a guy here and the yoke shafts are quite a bit farther apart. No bueno por cheet :evil:
Now I am curious what U yoke would work.
And who makes the best AC unit. :)
Re: Center stack
This what you're looking for? :lol:
54170b
Re: Center stack
Post by 54170b »
Im sure that would look great on my hat shelf
Re: Center stack
n2582d wrote:This what you're looking for? :lol:
Can't be any more drag than one of those Super Venturis :lol:
54170b
Re: Center stack
Post by 54170b »
Or a nosewheel
rsharp
Re: Center stack
Post by rsharp »
Here is an Avion panel installation on a '52B. Note there is also a fuel gauge for the aux tank forward of the flap handle.
Rick
54170b
Re: Center stack
Post by 54170b »
Thanks, Rick!
