Tailwheel towbar diagram
- Kyle Wolfe
Anyone got a diagram showing what it takes to build a tailwheel towbar, or a taildragger dragger? I'm thinking it can't be all that tough. But I haven't found anyone local who has one that I can copy.
Kyle Wolfe
N1932C
Kyle Wolfe
N1932C
Kyle,Aircraft Spruce sells a towbar for the Scott 3200 tailwheel that costs $38.50. I've seen a few home-made towbars & believe me,you'd be money & time ahead to just buy one from Spruce. That's what I did.
Or,you can use a piece of rope about 4 feet long for a leash,to pull your 170 around. A couple friends of mine prefer that to a towbar. Of course,it only works for pulling,not pushing........
I've used the type from Spruce for the past 5+ years and was satisfied with it. Although, it is still not great for pushing if there is an incline, or curve. I've pulled the plane out of the hangar buy the prop because of that. Just this week a fellow at the airport who had sold his taildragger gave me a much better tow bar. It slides underneath the tailwheel and lifts the tailwheel off of the ground. The tow bar has two wheels and two upright handles that allow you to push or pull with total control of the airplane while the tailwheel is lifted off of the ground, I really like it. The type from Spruce has an advantage in that it collapses so you can take it in the airplane if desired, this one that lifts the tailwheel does not collaspe and is much bigger.
51 C170A
Grand Prairie, TX
51 C170A
Grand Prairie, TX
Yep, that has to be about the best low cost mod a person can do. Going to get that one of these days soon hopefully. Might even be able to incorporate speed brakes into the design of the pop out handles!doug8082a wrote:Then there's always the BAS tailpull handles. More expensive than a towbar, but always with you - can't leave home without 'em.
51 C170A
Grand Prairie, TX
51 C170A
Grand Prairie, TX
What's it like crawling around in the aft fuselage with the BAS handles installed? I can just barely fit back there to work around the bellcrank etc. as it is. Mine's an A model, so it hasn't even got inspection holes to peek in at the bracket. I'd install the handles in a heartbeat (or as long as it takes) if I didn't suspect that I'd have to hire an anorexic contortionist next annual.
Tailwheel towbar
I also have a C-140 and belong to their association. They have a
maintenance advisor that has a diagram, parts list and pictures of a simple
tailwheel towbar that raises the wheel off the ground. It looks so simple
to build that I might even be able to do it. If you would send me your
mailing address I will send you a copy.
billmccown@usa.net
billmccown@usa.net
Yeah. The huge flaps on the B model are really good at slowing down, and flying so slow that A models fall. For really short field landings, I've resorted to a drag-chute. I'll probably have to use it to get slowed down to get a group photo with Joe's flat-wing.doug8082a wrote:Yeah, us "B" model guys have to watch it. Reduce too much too soon and we just drop right out of the sky. I usually wait until right over the threshold before reducing the power. That way I don't slow down anyone else in the pattern
Aahhh, we might be on to something! George, during climb, try flying without your drag chute being deployed! A good photographer could catch the classic straight wing look as I am passing by you in your bent wings. Looking forward to a group photo shoot.gahorn wrote:Yeah. The huge flaps on the B model are really good at slowing down, and flying so slow that A models fall. For really short field landings, I've resorted to a drag-chute. I'll probably have to use it to get slowed down to get a group photo with Joe's flat-wing.doug8082a wrote:Yeah, us "B" model guys have to watch it. Reduce too much too soon and we just drop right out of the sky. I usually wait until right over the threshold before reducing the power. That way I don't slow down anyone else in the pattern
You guys have safe flying and good weather going and coming from the convention, hope to make it next year.
51 C170A
Grand Prairie, TX
51 C170A
Grand Prairie, TX
