My '55 170B Project
- JohnNielsen
My '55 170B Project
I would like to share the excitement of this project coming to flight by early summer 2013. It began with a clean, damage free 170B w/o engine. We bought a 65TTSN O-360, had the cyl ported and polished, made it light and pretty, added an MT 3-blade composite constant speed prop, C180 float kit, V-brace, 172 baggage door, extended baggage, skylites from a 152, Cleveland dual cyl wheels/brakes, Federal AWB wheel skis, Sportsman STOL and Honer tips. The entire interior/exterior was soda blasted, zinc chromated then interior painted with military surplus aircraft interior grey enamel. The seats were stripped, powder coated and covered with Ceconite, then covered by Sport Aircraft Seating. Interior got all new cables, pulleys, fuel and brake lines and seat rails. There will be no insulation or plastic interior parts..keep it light. The panel will have the minimum required instruments per the TCDS and engine STC. A Garmin 496 in a Gizmos mount along with full engine monitoring and 'glass panel' (Not for primary navigation use ) by Grand Rapids Technologies. 8.50 tires and a new Imron paint coat will disguise the utility interior.
Here are a few pics. More will be added to this thread along the way and the full story will be found in print sometime in the future.
Thanks for your comments.
John Nielsen
John Nielsen
Re: My '55 170B Project
Nice John. Who's STC did your use? Where are your going to be operationg this 170 on those wheel skis. Florida.
You will have a real flyer there. A good camper.
John Hess
Past President 2018-2021
President 2016-2018, TIC170A
Director 2005-2014, TIC170A
N3833V Flying for Fun
'67 XLH 900 Harley Sportster
K3KNT
K3KNT
I lost my admiration for sky lights when I flew my Stinson L-5G down from Alaska back in about 1949.
The L-5, being basically an observation airplane, had a plexiglas top on the cabin and I flew it home on furlough from Fairbanks during the summer. I damn near got broiled in the summer sun down here in the lower forty eight. My first job on return to Alaska was to remove all the plesiglas and install an insulated metal cabin top.
The last time I looked, that old L-5 was still on the registry someplace down in Oklahoma. Damn, I sure did love that old airplane, N63970. Those were the days before the "warbird" movement and then it was just an old surplus Army plane and I sold it for $900. What the hell, you could buy a P-51 for $500 in those days.
- JohnNielsen
The engine STC we used is from DelAire. Got the interior painted and brackets fit for the ELT and EFIS Magnetometer. Firewall is positioned for riveting this weekend. The carpet is from a friend's C185...notice how well it fits in a 170B. Amazed at how much you can do and still be compliant within the rules of CAR 3. TSO and PMA were not known then. Manufacturers were able to use auto parts and common items that kept prices affordable. I believe the change and related costs of compliance to FAR Part 23 was the death knell of aviation for the everyday common man. Even the LSA planes are way over $100K mark.
You sure are doing some super good looking work on you 170. Should be a super plane when completed. You mentioned you were going to keep it light and I believe just having the required instruments so that may be the answer to my question, but I will ask anyway. While you had the firewall out did you consider converting the control yoke to a U vs the factory T which would permit a center stack?
- JohnNielsen
Regarding the yoke. Yes I did consider the Avion Research STC or similar that replaces the 170 yoke wiht one from a later model 172. It turns out it will not be needed to fit the EFIS that will be installed to this panel. There is enough depth to fit the EFIS just above the center cutout (that will house the Com and Xponder. See pic of proposed panel layout.
E.I. makes a combination Oil pressure/temp gauge. Allows you to get rid of one more gauge!
N8034A '52 170B #20886
Nice Job!
Be very glad you installed the rudder return springs with the firewall off.
_________________
Paul "Pablo" Britton
- JohnNielsen
Got the base coat of white done last night. Masked the paint line for the blue before leaving. Should get the blue and yellow trim done this week, then hang the engine and send it to the avionics shop for panel and electrical while Kris finishes the wings, tail and control surfaces. Getting exited!!
- JohnNielsen
We got the color coats on yesterday and unwrapped the masking. Looks great and Imron has such a wonderful deep luster. The small touches of chrome like on the steps, handholds, door latches and tie down really pops against the blue. Next step is to finish firewall and mount engine. John
Imron is hard to beat. While other products have neat-sounding market-names,.... I'll never forget how my old 206 kept receiving compliments on it's 26 year old, outside-storage-in-Texas-sun-and-WX Imron paint. It still looked fresh and crisp even when next to much newer airplanes.
- JohnNielsen
After some down time due to illness of one of the builders in this project, we are rocking ahead again. She is back on the gear with tail wheel and springs all refinished. The engine was mounted this week and the electrical shop is pre-wiring using a full scale mock up of the new panel. H-Stab is ready to mount. V-Stab is now painted and ready to mount. Windshield is fitted and ready to be secured in place. V-brace will go in just before that. When that is done, the plane will go the electrical shop for a few weeks to get all new wiring and the new panel installed.
- JohnNielsen
I have a tail!! The tail is now mounted, windshield installed, cowling has been fit and is being rivited this week. Elevator & rudder are painted and ready to install. Then it goes out to the Avionics shop for panel and wiring. While he is on that, the brand new wings will be painted and made ready for installation.
