I am servicing both of my Fuel Gauges in my '48 Cessna 170. The gauges have cork's for the floatation device and I was told that it is best to seal them with varnish. Do any fellow pilot's know how thick I should apply this varnish? I don't want to put it on too light and risk not filling all the holes in the cork/not sealing it well enough, but I also don't want to put on too many coats of varnish and risk making the bobbers too heavy so that they don't float in the gas. Any thoughts?!
Thank you!
Chris H
'48 Cessna 170
Cessna 170 Fuel Gauge Bobber/Cork sealant
Chris Hartis
'48 Cessna 170
"Failing to plan, is planning to fail."
'48 Cessna 170
Re: Cessna 170 Fuel Gauge Bobber/Cork sealant
Chris, if they were mine I'd coat them with as thin a coat as I would dare think completely sealed the cork and no more. A method model airplane folks used for years resin coating wings was to apply the resin thick enough to assure complete seal or fill of the weave of the cloth then use paper towels to blot or wick off the excess leaving a film. You could apply the varnish and do the same. BTW I'm sure someone might suggest a two part epoxy impervious to fuel to the varnish but applied just as sparingly.
Also you should know there are neoprene float available which could replace the cork. However this requires slight mods to get the cork of and the new float on and then something to replace the flat on the shaft that held on the float that had to be removed in the process. There have been writeups in the past how others did this. Perhaps someone could point to an article.
http://www.aircraftspruce.com/catalog/t ... floats.php
Here is a picture of this float on a similar gas gauge from Spruce. The page also has a PDF with drawings showing the washers used to hold it on.
http://www.aircraftspruce.com/catalog/i ... cfer=24050
- sgrimsley2717
Please check the 170 News second quarter 2012 page 10. My write up with illustrations. For a few dollars you can save a bunch of time and have a better solution. Steve Grimsley
- Kyle Wolfe
Is there a simple way (other than pulling the gauge) to ID whether it's the float versus the magnets causing erratic readings?
Would the gauge always show empty if the cork was gas logged while if it's the magnets it is erratic possibly?
Kyle
54 B N1932C
57 BMW Isetta
54 B N1932C
57 BMW Isetta
Can't think of any and I doubt you will see any sloop between the needle and the magnet. The sloop and erratic needle is from crude, loose gear mesh.Kyle Wolfe wrote:Is there a simple way (other than pulling the gauge) to ID whether it's the float versus the magnets causing erratic readings?
Erratic readings can be caused by slipping between the rod and the magnet at the head of the gauge. I have used epoxy to secure the joints. Has worked for many years.
Just need to make sure empty reads empty and allow the epoxy to cure.
When removing the cork from the end of the rod, you can put the rod end, that has been broadened/flattened to keep the washer on the rod, on a vise and carefully use a hammer to unflatten the rod end. After putting the new cork on the rod, use a hammer to flatten the end of the rod again. This has worked for mine for 10+ yrs ( following Steve Grimsley's guidance).
Cessna expands on what Dan writes in SEB99-18. There they call for the gauge to read empty with unusable fuel in the tanks.DWood wrote:Just need to make sure empty reads empty and allow the epoxy to cure.
