I don't need no stinkin' TW steering!
alaskan99669
Post by alaskan99669 »
Here's a picture of my TW springs:
And of a 170B on the other side of the strip:
I looked at several around the airport today and they are all very similar to the above photo's. I did have a CFI who has a bazillion hours in a 170 tell me I should tie a string to my TW springs or else one day I will find myself in a remote place and notice that one or both of the springs are gone.
Corey
'53 170B N3198A #25842
N2865C
Post by N2865C »
Thomas,
It looks to me like you found the right ones. Part #3239.
I posted the drawings on my site for now. I have not figured out how to post pic's on this site yet. It would be nice if they could be permanently kept in the library. http://cessna1200.tripod.com/id40.htm
Spruce has them hidden in the middle of the page.... http://www.aircraftspruce.com/pdf/catalog/Cat06240.pdf
N2865C
N419A
Post by N419A »
I would be a little concerned about using that tear drop clip the way it set up on that red tailed plane or the way it looks like it was set up on tshort's pics. My concern would be that those clips don’t always lay nice and flat together after slipping your chain or eye though it. I think you want that clip doubled acute angle end through a tight hole i.e. the chain link or the hole in the arm. The problem with having the spring on doubled acute end of the clip it could hook and pull under the doubled end while bouncing around as the chain goes from slack to tension, or the clip bounce sideways and be pulled apart.
That’s my thought if it makes sense. I'll try to take some picture for examples.
Later, Paul
Corey, ... the thing I noticed was that your leaf spring assembly does not appear complete. See the B model IPC, Fig. 29, items 15, 16, 17, 18. PN's 0542108 shackle, 0442125 guard, AN4-21A bolt, and AN365-428 nut.
The guard is the item previously mentioned which, if missing, can allow a slack chain to slip under the shackle and hang up. (Another method of preventing this is to slip a short piece of rubber hose over the shank of the AN4-21A bolt.)
Let me know via email or PM if you need these parts.
(Notice also, the red airplane's rudder skins were damaged at one time, probably by a flailing tailwheel when the main leaf spring broke. Keep those main leafsprings replaced. I recommend a 500 hour/cycle replacement schedule.)
tshort
Post by tshort »
Would that be the bracket that is present on the red tailed airplane?
Thomas
Thomas Short
1948 C170 N3949V
RV-8 wings in progress
Indianapolis (KUMP)
Yes, the red one has the bracket. Just can't tell if it has the guard.
tshort
Post by tshort »
So I've read the threads on the relative merits of the two types of springs and think I'm gonna switch.
Here's my question ... I see all the good reasons to go to tension springs; is there any real benefit to compression springs in this installation?
Most of the comments I saw re: compression springs were to the tune of "I've had them for years and had no problems".
Thomas
Thomas Short
1948 C170 N3949V
Indianapolis (KUMP)
lowNslow
Post by lowNslow »
N2865C wrote:I have not figured out how to post pic's on this site yet.
Maybe more then you really want to know, but:
http://www.phpbb.com/phpBB/faq.php?mode=bbcode
I don't know how the permissions are set for our forum, so some of this might not work.
N2865C
Post by N2865C »
tshort wrote:So I've read the threads on the relative merits of the two types of springs and think I'm gonna switch.
Thomas
If you had been landing in a gusty crosswind and lost it when the chains detached, your insurance company would probably not be obligated to pay out if they or the NTSB determined you were using unapproved springs. That's good enough reason for me. Of course we are all superior pilots and that would never happen to us :) .
N2865C
steve grewing
Post by steve grewing »
The main problem with compression springs to me is their inherent lack on travel in the event of a foul as described earlier. Once they bottom out something is going to bend. Whereas a tension spring will extend pass it elasticity and hopefully be the weak link in the mechanism.
Steve
