Franklin 6A4165
sphillips
Franklin 6A4165
Post by sphillips »
Are there any published performance numbers on this engine installed in "B" model?
Yes. The AFM (Approved Flight Manual), per Type Certificate Item 402 (g), as listed in the Type Certificate Data Sheet has performance data. To obtain a copy, contact Cessna, or a Cessna Distributor. (Hill Aircraft should be able to assist you. http://www.cessnaparts.com )
sphillips
Post by sphillips »
Thanks, George, but I was hoping to find info in helping me determine whether I want a "B" with this engine.
Do you want a "rare" variant with a hard-to-find-support engine? Is it worth giving up several hundred hours TBO, and then discovering the increased difficulty of finding the necessary parts to overhaul it? (I'm just being the "devil's advocate", on the personal level....not in any official capacity.) If you like Franklin engines, it'd be a great find (if the rest of the deal met your specs.)
