I will be in the process of re skinning all of my control surfaces and was wondering if someone knows of a good source for information on balancing for a 170A. Obviously the elevator and flaps are different then the B but are the rudder and ailerons the same?
Thanks for the help
Control surface balancing
control surface ballancing
call cessna and ask for service news letter SNL86-44, as well as NL83-8. The news letter snl86-44 says it supersedes nl83-8 however snl86-44 gives what weights to use for your flight controls but says to use the instructions contained in nl83-8. nick
Hi Kim,
Did you see the thread from a few weeks ago on this yet? Here's the link:
http://www.cessna170.org/phpBB2/viewtopic.php?t=3005
I haven't sent the SNL to George yet, but I will shortly. I can also fax it to you directly if you need it.
Matt
Matt
"Rule books are paper. They will not cushion a sudden meeting of stone and metal." (E.K. Gann)
- Kim Purcell
