Leaking brake master cylinder
N8249A
Post by N8249A »
One of my brake master cylinders leaks and I would like to replace or rebuild both. In addition it has the serated plunger which I recall someone stating they should be replaced. Anyone have a source for these parts? Thanks, Marty
Marty,
N8249A, 52' 170B
Hangar 130(North Hangars) KSAC
N8249A
Post by N8249A »
I guess I should call these the brake actuators ( the one on the pedals)
One of them leaks and I have to add fluid after every three flights or so.
Marty,
N8249A, 52' 170B
Hi, Marty!
YOu should look at the Spruce catalog adn you'll see they carry all the Cleveland repair/replacement parts. You can obtain the complete, new master cyl. Model 10-35 from them for $209 each. which will solve your serrated rod problem as well. (They also handle the overhaul kits.)
