Temporary Flight Restriction - SuperBowl - Houston
And this has got to be the most silly TFR of all. I mean, if the president is at his ranch, all you have to do to fly within 10 miles of the place is be on a discrete transpoder code and talk to ATC. Why in the blazes are football fans the subject of more security than the president? Why can't aircraft talk to ATC and get a code assigned just like they can at the president's "ranchette"?
The permanent Temporary Flight Restriciton area at the biological weapons plant at Pine Bluff, AR only requires you to stay above 3,000 feet. Is football more important than that?
FDC 4/0530 ZHU TX.. FLIGHT RESTRICTIONS. HOUSTON, TX.
EFFECTIVE: 0402011830 UTC (FEBRUARY 1 AT 1230 LOCAL) UNTIL
0402020430 UTC (FEBRUARY 1 AT 2230 LOCAL); PURSUANT TO TITLE 14 CFR
SECTION 99.7, SPECIAL SECURITY INSTRUCTIONS, ALL AIRCRAFT FLIGHT
OPERATIONS ARE PROHIBITED WITHIN A 7 NAUTICAL MILE RADIUS OF
294106N/952432W HOBBY/HUB/VORTAC 279 DEGREE RADIAL AT 7.13 NAUTICAL
MILES) BELOW FL180, EXCEPT FOR THE FOLLOWING:
1. THOSE AIRCRAFT ON AN IFR FLIGHT PLAN THAT ARE PARTICIPATING IN
THE SUPER BOWL SPECIAL TRAFFIC MANAGEMENT PROGRAM;
2. DOD, MEDEVAC, LAW ENFORCEMENT, RESCUE/RECOVERY, EMERGENCY
EVACUATION OR FIRE FIGHTING OPERATIONS THAT ARE IN CONTACT WITH ATC
AND ARE SQUAWKING AN ATC ASSIGNED DISCRETE BEACON CODE;
3. REGULARLY SCHEDULED PART 121 AND PART 129 AIRCRAFT THAT MEET OR
EXCEED THE TSA'S DOMESTIC SECURITY INSPECTION PROGRAM STANDARDS.
HOUSTON TRACON, 281-230-8441, IS THE FAA COORDINATION FACILITY.
TP
Post by TP »
AAh yes, Brought to you by the good people at Homeland security; but another goverment agency to protect us. And run up our deficit. :evil: TP
I must be okay cause, I haven't gotten a letter from the FAA.
jon s blocker
TFR
Post by jon s blocker »
It was put in place to protect Janet Jacksons celestrial orb.
N1478D
Re: TFR
Post by N1478D »
jon s blocker wrote:It was put in place to protect Janet Jacksons celestrial orb.
NAW! The TFR was failing, terrorists where within striking distance of harming 100,000 people, so they had performers trying to act and peform as if they were of a different ethnic background and that was still failing - so as the last means of defense they exposed the ultimate offensive weapon. The terrorists have not recovered yet from being boobed out of Houston. It is going to be dangerous times ahead for south Texas as the terrorists come up with their counter-boob attack, probably a double-boob flank attack starting around Lake Travis.
51 C170A
Grand Prairie, TX
