Distractions, don't let them distract you
Posted: Sat Jan 20, 2018 3:15 am
Accidents are seldom the result of one event, but a chain of events that lead to the accident, we are told. I demonstrated that to myself yesterday.
My intention was to gas up at the self service fuel pump at Grand Prairie, TX Municipal Airport, KGPM, then fly non-stop to Gillespie Co. Airport, T82, at Fredericksburg, TX. The weather was better than it looked and was not a factor in the flight, 3000' overcast with unlimited visibility and a 10-15k headwind. I had 19 gallons on board and it would take about 17 to fly to T82 so that left no reserve, hence the decision to fill up at KGPM.
It had been very cold for Texas the last couple of days with temps down in the teens in the DFW area. My 170 had been parked in my hangar at KGPM for two weeks while I was in Alaska and was thoroughly cold-soaked. So I had gone out the night before departure and hung two 100w drop lights off the lower motor mount to pre-heat with a padded moving blanket over the cowl to hold in the heat. The drop lights had increased the engine oil temp and CHT from 30°F to 50°F overnight and the engine started right up.
I taxied to the self service pump, ran my credit card thru the reader, reset and turned on the pump, then set up the hose and ladder like I always do. The system is always ready to pump by the time I get everything ready so, Mistake #1, I climbed the ladder and took off the right gas cap (before I knew the pump was running) but no gas came out of the nozzle. So, Mistake #2, I climbed down without replacing the gas cap and went over to the card reader which showed the transaction did not go thru. I ran the card again and the same message came up again.
Since I had just returned from Alaska after two weeks I thought the credit card fraud-detection had kicked-in again as it sometimes does when it detects charges in Alaska then charges in Texas. A quick call to the credit card company indicated the card was good and should work so I went into the airport office and told them the gas was not working. The attendant admitted the same problem had happened in the last few days and obviously was not fixed yet. I suggested he put a sign on the pump so others would not waste 20 minutes discovering the same thing.
I walked back to the plane and rolled up the hose then, Mistake #3, put up the ladder without replacing the gas cap. Since I had already done a pre-flight at the hangar and drained gas sumps there, Mistake #4 I did not do another pre-flight which would have detected the gas cap being left off. Mistake #5 was not realizing I had been distracted.
Since I wasn't in any hurry, I decided I could fly toward Fredericksburg and stop along the way for fuel at one of the many airports along the way before I ran short of fuel. So I departed KGPM and headed to T82. Right after takeoff the left tank showed 1/2 full and the right tank showed 1/4 full.
About 20 minutes into the flight I checked the gauges again and to my amazement, I was shocked to see the left tank showed almost empty and the right tank showed over 1/2 full. That did not make sense so I quickly started thinking about what might be causing it. It didn't take long to realize I had left the right gas cap was off which then made sense. The open filler neck was creating lower pressure in the right tank which was drawing fuel from the left tank into the right tank. The engine was still running fine and the cap was not banging on the wing so there was no indication of a problem other than the gas gauge issue.
There was no fuel flowing off the trailing edge of the right wing so I felt a little better but I knew I needed to land and take care of the problem. Mistake #6 would have been if I had not checked the fuel gauges again but I knew I needed to stop somewhere and I regularly check the tanks anyway to see how they are feeding. This is the first time I had an unusual gauge indication in all the years I have flown the plane. I still had lots of gas so it was not critical to land immediately but I was only a few miles from the Cleburne Municipal Airport, KCPT, which had self service gas so I turned toward Cleburne. Landing was uneventful and nobody noticed the cap was off. The pump worked like it should and I topped off both tanks. Cleburne has a very nice terminal and there was lots of activity inside, good to see at a small airport these days.
To my amazement, there was no evidence of fuel being sucked out of the open filler neck on the right tank. I filled the right tank first to see how much was left in it. It took 6 gallons. The left tank took 13 gallons and the fuel flow computer said I had 16 gallons left in the tanks so with 19 gallons in the tanks at departure, running the numbers agreed no fuel had gone overboard.
It was surprising to me even though the fuel transferred between tanks, none had gone overboard. Thinking about it, it makes sense because the levels were half or below. Had both tanks been full, no telling how much would have siphoned out but as it was, nothing happened.
I continued the flight to the southwest and flew over member Bob Jolly's ranch but his motor home was gone so I suspect he and Pat were out on the road somewhere. I flew another 12 miles and landed at another friend's ranch strip northwest of Lampassas for a short visit. Rusty videoed my landing and I taxied to the downwind end of the 2000' strip in preparation to leave in an hour or so. Everything was fine when I left the plane but after an hour it was getting late and was time to go before dark. Rusty took me back to the plane and I couldn't believe it but the left tire was flat! Murphy was still hard at work. We rounded up some tools and a hi-lift jack was used with a piece of pipe over the jack column and positioned at the wing tie down ring. The wheel was off and taken apart by dark.
Nothing wrong could be found with the tire or inner tube, no cuts, stickers, or nails, except, the valve stem was missing! We looked at the video Rusty had taken from final approach all the way to where I shut down and both tires were inflated the whole time, yet the valve stem was missing and could not be found and the tire was flat an hour later. Go figure!
Once taken apart, the inner tube revealed it was actually the wrong size tube. Instead of a 6.00-6 tube it was a G15-6.00-6 tube which is for a smaller tire. I don't know how much that had to do with the flat but it was a noticeably smaller tube than the replacement 6.00-6. The wheels, tires, and inner tubes had been installed new in Alaska in 2006 by the shop that did much of the restoration work and they have never been taken apart since then. So I don't know what happened but I'll be talking to the shop about it. Now I have to take the right wheel apart and see if it has the correct tube.
All in all, things worked out well after all the mistakes made and problem with the inner tube. Had the tube blown while in the air, I would have landed not knowing it was flat and no telling how that would have turned out.
Bottom line is don't let distractions get in the way. When distracted, start over whatever you were doing and go thru it again without the distraction, they can bite you.
