Re: Long Pawl vs Short Pawl on ABW 3200 TW
Posted: Wed Oct 25, 2017 3:55 am
I talked today with someone very familiar with the L-19 (amazing what you can learn when walking around airports and hangars).
Early L-19; Tail section is identical to the 170B...identical. The only differences to the exacting eye; the L-19 horizontal stab has a row of rivnuts on the outer ribs, top and bottom for the attachment of ventral fins for float ops and L.E has provisions for homing antennas. All parts have zinc chromate finish. After an upping the gross weight made to the L-19 by Cessna, now the parts are a bit different. Trim tab is bigger, screw jack bigger, the main tailwheel spring is beefier, the spring stack has three leaves, the fish mount is a bit different at the aft end (no notch), the U- bolt is heavier, the plate (fitting) on the top of the fish mouth does not have a tail and the tailwheel has the turned up arms which are heavier for exactly the reasons George previously mentioned.
I've got to return to this airfield to get another lesson and get another tour to take pictures.
