Lemon Pledge
Re: Lemon Pledge
Here's what LP Plastics, "the world's largest manufacturer of light aircraft windshields and windows", recommends. As the original subject was Pledge, I've highlighted what they say regarding furniture polish. It echos what other posters have already said.
When cleaning a window, always remove as much abrasive dirt as possible without touching the surface. Ideally this would involve flushing the surface with water and allowing the accumulated bug residue to soak, possibly with a little dish washing liquid added to the water. If a little rubbing is needed, do it lightly with your bare hand. After a final flushing with more water and carefully drying with a clean soft cloth, use a good grade cleaner/polish intended for acrylic windows, following the manufacturers directions.
We need to step back here and take a look at cleaner/polishes. Everybody seems to have a favorite, from great and proper to poor and very dangerous. The good ones, at least those that are safe to use on acrylic plastics, tend to be the commercial ones, intended to be used on this specific material. The bad ones, including the very dangerous, tend to be materials never intended to be used as an aircraft window cleaner/polish, such as glass cleaners and furniture polish. Glass cleaners invariably contain ammonia, a killer of acrylics. DO NOT use anything containing ammonia on acrylic plastics. It will cause crazing (thousands of microscopic cracks) in short order. Furniture polish seems to be safer, but its long term use is undocumented and reports indicate it builds up and produces smears that are hard to polish off. Something to consider about furniture polish - it is intended to be used indoors, not outdoors, and on furniture, not aircraft windows. Furthermore, it's not much less expensive than many aircraft window products.
Good and safe care products vary in their ease of use and other properties, so if you don't like what you're using, give another a try. Talk with other pilots about what they are using, but be sure the product you select is intended for acrylic windows. Other products to keep away from your windows include any aromatic solvent, such as methyl ethyl ketone, acetone, lacquer thinner, gasoline (a minor fuel spill should do no harm), and, heaven forbid, paint stripper. If you have to remove masking tape residue or other sticky or greasy stuff, the safest solvents are 100% mineral spirits or kerosene. Some alcohols are safe, such as isopropyl alcohol, but not all.
Concerning the polishing cloth, use the softest cotton cloth available. One hundred percent cotton flannel is ideal and available in yard goods stores. Old washed-out cotton T-shirts are a good second choice. We at LP Aero Plastics have never found a paper product that did not scratch, even those advertised for cleaning plastics. One benefit of cotton cloth is that it can be washed, thereby effectively recycling the material.
Your choice of cleaner/polish should also be based on what is needed. Basically, you have to determine what type of care is needed and pick the best products to do the job.
First, it's best to understand what types of products are available. They can be loosely grouped into three categories:
1. Non-abrasive liquid sprays, in pumps or aerosols, that may or may not have scratch filling properties.
2. Non-abrasive creams that have scratch filling properties.
3. Mildly-abrasive creams that have scratch removing properties.
Since windows do accumulate minute scratches as part of everyday life (the kind you can't feel with a fingernail but can really see when flying into the sun), the products that fill fine scratches are great for regular use. If scratches still appear when flying toward the sun, the abrasive variety and some elbow grease is called for. This type of cleaner should be used occasionally only as needed. Most manufacturers of abrasive cleaners recommend following up with a scratch filling product as a second step.
The bare hands folks find support from the FAA. AC43-13-1B, Chap. 3, Sec. 4 says:
Cleaning. Acrylic windshields and windows may be cleaned by washing them with mild soap and running water. Rub the surface with your bare hands in a stream of water. Follow with the same procedure but with soap and water. After the soap and dirt have been flushed away, dry the surface with a soft, clean cloth or tissue and polish it with a windshield cleaner especially approved for use on aircraft transparent plastics. These cleaners may be purchased through aircraft supply houses.
Re: Lemon Pledge
That's good info.
And I'll add a tidbit.... when using ALCOHOL, ...notice they say some alcohol is safe..."but not all". This is because some regulations controlling alcohol are designed to make certain that it cannot be used illegally as a beverage... therefore it is commonly/adulterated or "denatured" with other offensive products such as acetone, MEK, or petroleum-spirits/ethers to make it offensive to taste and disruptive to the digestive tract. These "denaturing agents" can ruin acrylics, plastics, and polycarbonate (Lexan) plexiglass type windows.
IF you ever use methanol or isopropyl alcohol near your airplane make CERTAIN it is 100% pure (or mixed only with distilled water or other safe product.)
Re: Lemon Pledge
Off topic but I have a friend who was an engineer at an ethanol plant in California's central valley. He said they added gasoline to every batch of ethanol they made for the same reason -- to make sure it wasn't used as a beverage.
Re: Lemon Pledge
Thanks for all the good information. I have used Clear View products ( in my plane now) as well as Novis cleaner (doesn't appear to be available at AS in bulk any longer.) I've read the bit about water and the palm of ones hand. I've tried it and it's fine . Have to have a source for running water ( yea, I have buckets, etc). Sort of makes a mess on hangar floor and on cowling but better than replacing windshields!
Anyone need some Pledge for your furniture? Afraid Becky might want me to use it on our furniture if I take it home :lol:
Re: Lemon Pledge
johneeb wrote:
cessna170bdriver wrote:I used to use Lemon Pledge religiously until someone pointed out to me that the manufacturer is under no obligation not to change the recipe to include something not friendly to acrylic. It will probably never happen, but why take the chance? Water is the most universal solvent on the planet and is known to be acrylic-friendly. About 4 ounces of di-hydrogen monoxide and a bare hand, followed by the acrylic-friendly drying towel of your choice will get it as clean it's ever going to be.
But don't leave your weeding ring on the cowl when you are done cleaning the windshield, it may not be there after you land! :-)
I've been practicing, and I can now clean both sides of the windshield with my (ringless) right hand... while standing on the the tires. Come to Deming and I'll demonstrate! :lol:
