Install Diode
Posted: Sat May 13, 2017 11:21 am
First item on cockpit Check List was radios "OFF" w no explanation.
From this forum learned that turning master switch off and on could send transient voltage "spike" of up to 600 volts throughout the electrical systems. Radios "off" prior to start up and prior to shut down protects.
I just purchased from A/S the ACS diode assembly kit 16050-2.
My contactor is orig 1954 w translucent cover. IPC is no help.
Bruce covered the changing terminology used by Cessna.
How do I install the new diode (60 years late) with the old original translucent contactor cover ?
