C145 inner cyl baffles have a short and a long leg. There is a right and a left baffle so either the short leg goes toward the front of the engine or the long side does.
Which way is correct is the question of the day.
C145 inner cyl baffle direction
Re: C145 inner cyl baffle direction
I think you would want the long sides on the outer cylinders. If you point them to the inner cylinder, I think they would touch or overlap restricting all the airflow over the inner cylinder. I'll have to look at mine again when I'm at the shop.
1952 170B
N8180A s/n 25032
N8180A s/n 25032
Bruce, I just checked with Airforms who I got my kit from. With the little tab pointed to the case, the large "legs" should point aft towards the firewall.
1952 170B
N8180A s/n 25032
N8180A s/n 25032
Thanks Mike.
