C145 inner cyl baffle direction
Posted: Tue Mar 28, 2017 2:23 pm
C145 inner cyl baffles have a short and a long leg. There is a right and a left baffle so either the short leg goes toward the front of the engine or the long side does.
Which way is correct is the question of the day.
Re: C145 inner cyl baffle direction
Posted: Tue Mar 28, 2017 6:50 pm
by nippaero
I think you would want the long sides on the outer cylinders. If you point them to the inner cylinder, I think they would touch or overlap restricting all the airflow over the inner cylinder. I'll have to look at mine again when I'm at the shop.
Posted: Tue Mar 28, 2017 6:58 pm
by nippaero
Bruce, I just checked with Airforms who I got my kit from. With the little tab pointed to the case, the large "legs" should point aft towards the firewall.
Posted: Tue Mar 28, 2017 11:23 pm
Thanks Mike.
