Replacing Cables
Posted: Tue Mar 07, 2017 2:11 am
First off, at next annual, disconnect the rudder cables at the rudder and pull them ALL the way forward and inspect for broken wires.
95D has 1,400 hour total time and the wires felt like a porcupine. I woudlnt have been able to tell with the cables still attached.
So, I decided to buy a full set of replacement cables.
My plan is to pull each pulley one at a time to prevent mass confusion. Clean, inspect, lube and re-install finger tight. Replace hardware as needed (I pre-ordered a lot)
This allows me to make one order for bad pulleys but not need to take everything out at once.
I plan to pull the new cables thru when I pull the old one out with a length of safety wire. as the new cable passes each pulley, I will torque that pulley and mark it with yellow paint (torque seal)
I cant tension any of the cables except for the elevator for now.
Pulleys will be lubed with a synthetic bicycle chain lube designed to repel water, keep out grime and prevent corrosion. I chose this oil because bicycle chains endure far more abuse than these pulleys and the stuff is quality oil.
The 100 series repair manual says to leave the cables dry unless you're in a marine environment.
The job seems fairly straight forward if not a little meticulous.
What am I missing?
Also, what are the center to center lengths of the rudder cable straps that attach the cables to the rudder? MIne are missing and I need to fab a set.
What am I missing?
