Preheating
Re: Preheating
hilltop170 wrote:.... A 100W drop light will keep an engine warm ....
If anyone still has 100W incandescent lamps. (I squirreled-away a few before they were “outlawed”...but the church talked me out of them to keep a water-line in an equipment-room from freezing.)
Re: Preheating
The local home improvement box store sold out of incandescent bulbs years ago for $1 per 4 bulb carton. I bought out everything they had. 8O :idea: :lol:
Re: Preheating
I did a trial to get some actual pre-heat data using two 100W drop lights (yes George, incandescent lights) under the engine with minimal insulation of one moving blanket draped over the cowl, starting from a not-so-cold, cold-soaked condition of 45°F ambient air temp with measured 55°F cylinder head and oil temps inside an uninsulated closed T-hangar so no wind.
In 12 hours, the oil and CHT temps went from 55°F to 75°F while the ambient air temp fell to 40°F. Once the engine was started, the oil temp initially remained at 75°F indicating the oil and engine internals were heat-soaked at 75°F, a 20°F increase in 12 hours.
One moving blanket over the cowl
Two 100W drop lights hung off the engine cradle
Re: Preheating
One might consider a practice of Turning your FUEL VALVE to OFF if you use heaters beneath or anything using electricity inside your engine compartment.
iowa
Re: Preheating
Post by iowa »
i'm going to use the milk house heater with dryer ducting
as i prefer anything that is potentially red hot or prone to break
sitting away from my priceless airplane
https://www.youtube.com/watch?v=5b-4yn2qj-I
the bulbs are a cheap simple solution, but c o u l d destroy your airplane and hangar
it seems logical that the above method would less likely to do this if untended for a few hours
dave
1951 170A 1468D SN 20051
AME #17747
