Name change for the Eternal Project
Re: Name change for the Eternal Project
Wow, that's beautiful work.
I met Del when he was sizing up Miles's aircraft in St Louis. After hearing about 30 secs of conversation between Miles and him, I realized this is someone who's knowledge far exceeds so many in GA. Paul you couldn't have done better anywhere.
Del's words are such an understatement of his ability and workmanship that 30 seconds from him is about all anyone would need to relax about concerns. (It's a shame he can read these comments, but his head is probably the only one in the industry that wouldn't grow oversized with this sort of praise.)c170b53 wrote:Wow, that's beautiful work.
Sorry George, you know me, always stating the obvious
Thank y'all for the compliments. I appreciate them. I want everybody to know, I don't do this alone. I am just one among many.
I had good intentions of posting a good detailed update to the progress on Paul's plane, but I've been busy with other things. Like today, I mowed the yard (the hangar yard) and sprayed some roundup. That's some good stuff, just don't accidentally sprinkle any in your beer.
Thanks guys!
Thanks guys!
Del Lehmann
Mena, Arkansas
Mena, Arkansas
Here are a couple pics from Friday. The top side is done. We will finish the lower surface tomorrow. I told Paul that Brett and Wayne save the easy stuff for themselves. I'm the small guy, so I get stuck with task that require duct tape and Vaseline I'm already home and my Internet is really slow out here so this is all for now.
The dull areas along the rivet rows are that way on purpose. We use Scotchbrite along the rivet rows before we even place the skins on the wing. It helps the painters (and us) to stay away from the rivet heads when prepping for paint. When we build a plane the last thing I want to see ( don't want to see) is newly installed rivets that have been sanded off. I like to be able to identify the type rivet AFTER paint. It doesn't always work, but we try.Del Lehmann
Mena, Arkansas
Mena, Arkansas
Paul saw how mirror like the new skins are, and almost opted for polish. Oops, to late Ethel. When we do a re-skin on something that will be polished, we order our material from another vendor that supplies it with a protective coating which stays on the aluminum sheet until we actually start shooting rivets. Then we peel it off a little at a time as we shoot. And of course we don't scuff the rivet rows as we do on a product that will be going to paint.
The right wing is finished. We would have finished the left wing tomorrow, but the parts guy had his hat on backwards and let Wayne run out of .020" So the date will get pushed to Thursday. Friday we plan to take all surfaces, everything except fuselage, to Darrell Mos so he can start prep and paint.Del Lehmann
Mena, Arkansas
Mena, Arkansas
Del, Is your hat still on backwards?
Another happy customer,
Jughead
Jughead
I wear many hats, and clock them differenty on my noggin several times a day. So, I can't answer your question with any degree of certainty Thanks Johncounsellj wrote:Del, Is your hat still on backwards?
Jughead
Del Lehmann
Mena, Arkansas
Mena, Arkansas
Hey Paul! A rich guy like you could always ask Del to drill off those new skins on that ETERNAL PROJECT AND START OVER!
Actually, Del didn't quite catch the sarcasm in my email. I am far too lazy to be a polish hound, besides I don't want to be buying WD40 by the gallon
My biggest concern is how much all that green primer is going to slow the old girl down! I tried to tell Del we needed to use the faster red primer ! Maybe there will be enough red on the outside to compensate for being green on the inside.
Paul, don't compel me to disclose our secret. There are some pictures that haven't been posted. I thought you wanted to keep it a secret until after you smoked George at Reno
Del Lehmann
Mena, Arkansas
Mena, Arkansas
A day later than planned, but ready to go to paint shop now
Del Lehmann
Mena, Arkansas
Mena, Arkansas
Del, is that a low wing tail-dragger in the background of your latest picture (wing looks great)?
I see you are again dispensing some Arkansas wisdom in red "DO NOT DOUBLE STACK".
It is a low wing tail dragger, ag plane. I just realized what a poor photo that was. There is actually a Clipper parked right in the bright light, to the left of the high wing jack. You can barely make out the "shadow" of the wings. Wow, that's a bad lighting angle.
Del Lehmann
Mena, Arkansas
Mena, Arkansas
Is that RED rib one of Paul's originals?
