Tail wheel play
Tail wheel play
I'm at the hangar doing the annual and on a phone so searching is tough. I have the tail on a jack to repack the tail wheel bearings. When I grab the tail wheel and wiggle it there is a little bit of play. I am only rotating the assembley a fraction of a degree but the rear of the tail wheel is moving almost a half an inch. This is free play and the steering arm is not moving above it. Is this normal?
Re: Tail wheel play
Can you describe exactly what is moving?
The Scott Tailwheel only? The Tailwheel spring in the bracket or is the bracket itself moving on the airframe?
None of those should be moving that much but its tough to tell what might be lose or missing by your description.
Re: Tail wheel play
It sounds as if your pawl and pawl spring (and perhaps associated parts) are failed. The best thing is to remove the tailwheel assy and disassemble completely for inspection.
Re: Tail wheel play
your play is between the compression spring mounted on the fork and the steering arm where it engages the arm. It could be the steering arm worn, the spring worn or both. you will have to disassemble and inspect to know for sure.
Re: Tail wheel play
Item 22 is the compression spring.
Re: Tail wheel play
Sorry guys, I misread the initial post. Didn't mean to cause any confusion.
Re: Tail wheel play
Fred has it about right. I always seem to find a little bit of play here, The connection is not rigid.
Re: Tail wheel play
What would be considered an acceptable amount of play? I imagine there should be some but how much?
All work and no play is never a good thing.
Re: Tail wheel play
that is the million dollar question. how much play is acceptable?
thanks.
thanks.
Re: Tail wheel play
That play is not adjustable, it is caused by clearance between the compression spring, Item #22 in the diagram and the steering arm, Item #10. Is the play causing a problem that caused you to check it out like shimmy, hard to swivel, or loss of steering (beyond the already poor steering)?
If not, there is nothing that can be done short of replacing worn parts. It's probably worn pawls in the steering arm. It sure won't hurt a thing to take it apart, clean it, inspect/learn how it works, re-lube it, and put it back together and then you'll know how it works. Obviously, if there are any failed parts, replace them and possibly the part they engage with that are worn.
I think how much play is acceptable is subjective, if you are comfortable with it and there are no failed internal parts, fly it.
Re: Tail wheel play
The answer is the amount of play you will tolerate. Now send money to my Paypal account.buzzlatka wrote:that is the million dollar question. how much play is acceptable?
thanks.
Seriously. If the play bothers you, replace parts. I doubt you will notice a difference in the steering new parts or old. I doubt if replacing the worn parts will do anything to increase the life of the other parts involved.
So it really comes down to what yo find acceptable.
Re: Tail wheel play
Very helpful posts, thanks! My tailwheel is a little loose and is about to get some new parts....
Charley
N2704C
N2704C
Re: Tail wheel play
I have an old scot 3200 laying around the hangar. I am going to take it apart and play with it and try to understand the inner workings. Thanks for the advice. If I decide to replace parts at least I will have had some practice.
- daedaluscan
Re: Tail wheel play
I had this same issue with my new to me 170 isent the wheel to Alaska bushwheel in Portland and was delighted with their service. One hour labour for the rebuild. I had dissasembled it
Charlie
1956 170B C-GDRG #27019
