Windshield reinforcement strip
Hello all, So I am new here. So I guess I should give a little info about myself. I am a Helicopter CFI/CFII and a Airplane private pilot, currently in school to get my a&p. Love the 170 and am currently working on one at school.
Which brings me to my question. The 170 I am working on is a full rebuild for a WWII corsair pilot, (which I thought was pretty cool) and we are putting in a new windshield. The windshield is from LP aero, and they told me because it is the original 170, the STC for a one piece windshield is not allowed.
The center reinforcement strip is missing, and as far as we have found, it is unavailable. So we need to build one. Does anyone possibly have to measurements on this. Mainly the width, and thickness of material the factory used on the inside and out. Thank you so much for your time.
IdahoPilot
IdahoPilot
Ken Nimer
1948 Cessna 170 Ragwing.
Re: Windshield reinforcement strip
All 170 windscreens are one piece.
The center strip is a reinforcement because the original window was thinner.
I've seen quite a few 170's without the center strip that used new (thicker) windscreens.
You might want to re-verify the details of the STC before drilling extra holes in your new windscreen.
First, welcome -- you'll find a lot of information here. Some might even be useable!
If you find you need the center strip here's what I would suggest: The inside center strip on the straight 170 calls for p/n 0510000-8. This has been superseded to p/n 0510000-16 which is the same number as the early serial number C-170B's use. That strip is around 3/16" thick. Rather than buy the material to scratch build this part I think it would be cheaper to place an ad for one in our Trademart, the Association's Fly Paper, and/or online at Barnstormers. There have to be a lot of these strips (both inner and outer) gathering dust in hangars as the conversion to strapless is quite popular.
If the owner is not concerned about originality a windshield from Great Lakes Aero Products might have been a better choice. They are approved without the center strip. SA210GL
The center strip is not optional on thin windscreens even though they are one piece. That strips' primary function is to retain the windscreen in the frame thus preventing a unplanned blowout type departure.
The thicker windscreens are center strip free only because of the alternate retention methods incorporated into the STC's. Usually either through machine screws passing through the upper windscreen/retainer strip or a plastic strip glued to the windshield plus a sheet metal retainer strip that takes the place of the old upper retension strip. (retains the upper windscreen area to the forward carry through spar)
AS suggested, research to see what windscreen is installed first and then go a search'in
As an asside: I have seen many strips broken, cracked, corroded or severly bent and still somehow passing inspections.
After some checking, the windshield we have does in fact need the center strip. And I have looked all over for replacements, and am about to place an ad for one.
Does anyone have the actual dimensions?
IdahoPilot
IdahoPilot
Ken Nimer
I have an intact inside strip (thick) and an outer (thin) strip that broke near the top. Portions of both parts can be seen in the second photo here: http://cessna170.org/forums/viewtopic.php?f=24&t=7897
How does $25 sound? I'll ship. Or, if you'd like I'll run out to the airport and measure them.
Warning-potential thread hijack!
What is the weight difference (installed) of the older/thinner plus retainer strap, versus the newer thicker version? Ounces? A pound? Couple pounds?
Yeah, I know it shouldn't matter compared to the increases in visibility, but ...
If a guy had a dream, and it involved a 1100# 170B, every pound might matter.
Lightweight starter...
Lightweight battery...
Removal of extraneous gauges/dials /wiring/venturies/seats/interior/paint and random trips to the super-bar at wendy's...
EDIT: from the great lakes aero page, STC data, looks like the newer version adds 3.8#s! So...
Don't forget the 8.50's, 180 gear, big tailwheel etc, etc.
We may have to take you up on that. Especially with the thickness of the inside piece. If you have time, it would be awesome to know the dimensions though.cessna170bdriver wrote:I have an intact inside strip (thick) and an outer (thin) strip that broke near the top. Portions of both parts can be seen in the second photo here: http://cessna170.org/forums/viewtopic.php?f=24&t=7897
Ken Nimer
Remember all folks are welcome to participate in most of our forum areas. I'm glad IdahoPilot came here and asked the question and it seems Miles has a very reasonable solution to his problem. But Idaho Pilot is not a TIC170A member so he can not advertise here at our TradeMart. Perhaps he'll see fit to get even more interested in a 170 and then when can pressure him in to joining the association.
Personally if I could, being a fellow helicopter pilot, I'd like to cut IdahoPilot some slack and let him advertise in the TradeMart. We'd have TIC170A member privileges, Helicopter Pilot privileges, which would be darn near as good, and then everyone else. Good think it's not up to me.
Amicable divorce, Military Intelligence, Good Lawyer, Helicopter pilot.....
Are you sure they are not a member? I was able to PM them and got a reply, and their bio shows them joining on the 5th. I've all ways believed rotor heads need a little slack.
shotgun34 L-19 #884 70-71 Chi Lang
PM's work on participants (non TIC170A Members) and Members alike. If their username (profile) does not show a Member NUMBER...they are not registerd at the forums as a TIC170A Member (and if their username at each post does not show an avatar or TIC170A logo, they are likely not a TIC170A Member.)runerider wrote:Are you sure they are not a member? I was able to PM them and got a reply, and their bio shows them joining on the 5th. I've all ways believed rotor heads need a little slack.
I must be looking at the wrong viewing profile I don't show a # and neither do you. I am also one with shame since I'm a holder of a rotorcraft-helicopter and instrument helicopter .
Its true I am not a paying member. I joined the forum on the fifth.
Ken Nimer
