Fuel guage repair
Re: Fuel guage repair
I think that the original guages were "Scott" and not truely a "Cessna" mfg.
In reference to all the concern regarding "approved" fuel gauges and parts: This summer's convention mx seminar was addressed by Rick Anderson, DTO-FSDO who spoke at length regarding replacement parts for aircraft type certificated prior to Jan 1980. In a nutshell: buy the darn parts and install them. Log it, and record the source. Be happy. You're legal.
read the advisory circular here http://rgl.faa.gov/Regulatory_and_Guida ... 023-27.pdf
Walt Weaver
Spencer Airport (NC35)
To answer your question - yes the Spruce gauge works fine. The gauge comes with a long straight float arm so that it can be adapted to different tanks. You will have to shorten the arm and bend the end 90 degrees to attach the float so that it is horizontal and parallel to the bottom of the tank. The gearing is different than the original gauge so that the arm will swing about 150 degrees from "full" to "empty", on the original gauge the arm swings about 35-45 degrees. I don't remember the exact measurements but you can figure it out by measuring the inside depth of your tank.Bikini wrote:gahorn,
did you have to modify your guage at all for it to work in a 170? There's a whole discussion about having to shorten the arm or something. or is the Spruce product fit our plane?
Bill
gahorn wrote:In reference to all the concern regarding "approved" fuel gauges and parts: This summer's convention mx seminar was addressed by Rick Anderson, CHI-FSDO who spoke at length regarding replacement parts for aircraft type certificated prior to Jan 1980. In a nutshell: buy the darn parts and install them. Log it, and record the source. Be happy. You're legal.
Can an owner do this or do I need to
Convince my A&P??
Bikini
High Point NC
F-16, B727, A300, C170B
High Point NC
You need to convince your A&P to supervise your work.
That's good to hear, did he put it in writing?
Tim
I think George's statement is pretty general. AC 23-27 spells out some specific things that can be substituted and general guide lines for others. It appears by this AC that the FAA is taking a bit more logical look at some of these parts and agreeing that if it looks like a duck, flies like a duck and quacks like a duck, it just might be a duck. That was the message from Rick Anderson who is a Cessna 175 owner himself.
If only more FAA folks fell in line with what Anderson was preaching.
He utilized a Powerpoint presentation which provided references to FAA legal opinions and Advisory Circulars.mit wrote:...That's good to hear, did he put it in writing?
When I asked for a written opinion on particular issues he answered that written opinions will be provided in response to written inquiries. (Sensible and correct response.)
There's no reason to belabor the point... if you want a copy, then get in touch with him, he's an inspector at DTO-FSDO, name Rick Anderson. Easy to find. (and it was an FSDO-produced presentation based upon an FAA Advisory Circular available on line, a copy posted above.)mit wrote:Then did you get a copy of the Power point and his talk on tape?
Errata: Corrected FSDO to Detroit.
is this the best thread on how to replace/overhaul a gas gauge?
thanks
dave
thanks
dave
1951 170A 1468D SN 20051
AME #17747
lowNslow wrote:To answer your question - yes the Spruce gauge works fine. The gauge comes with a long straight float arm so that it can be adapted to different tanks. You will have to shorten the arm and bend the end 90 degrees to attach the float so that it is horizontal and parallel to the bottom of the tank. The gearing is different than the original gauge so that the arm will swing about 150 degrees from "full" to "empty", on the original gauge the arm swings about 35-45 degrees. I don't remember the exact measurements but you can figure it out by measuring the inside depth of your tank.Bikini wrote:gahorn,
Bill
I just received two of the Spruce gauges to replace my fuel gauges. They have too much throw to work the same as the original gauges. If you were to adjust it to show full accurately then it will show empty way early. If you adjust it to show empty correctly it will never show full. I’ll be returning and looking for a place to refurbish my gauges.
Below are pictures of the original and Spruce gauges at their full travels. You can see in the first picture that the Spruce gauge has a lot more “up” travel.
Doug, it appears all you need do is shorten the rod to the appropriate length to mimic the OEM gauge.
Doug,
It looks to me like your original gauge must have been indicating "full" until it was nearly half-empty. The gauge is mounted in the middle of the tank vertically so when the float arm is horizontal the gauge should read half-full (or half-empty depending if you are an optimist or a pessimist ). According to the installation sheet I posted here, "The float length dimension (measured from the float pivot point to the end of the float) should be proportional to the inside tank height and is usually less than 1/2 of the vertical inside height of the tank." SEB99-18 Revision 1 says to drain all your fuel from the tanks and then, with the fuel valve off and the aircraft leveled, add unusable fuel to each tank. The gauges should read empty. Next fill the tanks and confirm that the gauges read full.
