I am rebuilding my 53-170-B which already has the Bush Conversion for a Lyc. 180hp, w/CS prop. Need Motor Mount tweaked in a bit but am unable to get ahold of "Bush Conversions" at all much less find out about the mount off-set anbles. Rumor has it that it is 1 degree down and 1 degree to the right. Any data at all would be greatly appreciated as this has become my show stopper.
Am also putting in the Delair Long Range Tanks and have solved almost all of the problems associated with same in case anyone else is interested.
Bush 180hp Cnvrsn, motor mount angles, degrees right & d
long range tanks
Hey Chris, How about giving us some info on Harrys long range tanks. Give us a little bit on what mods you need to make on the wings, and any other mods you need to make. How long did it take to do the mods? Thanks, Jon
