To the new members.
The messaging system works good but has a huge limitation.
You cannot receive responses from other members unless you remove old messages on your account. The limit is 10.
To the member:Aaron who is trying to solicit flight training. Your inbox is full and there are messages waiting for you. To others if you sent a message to someone and the message you sent is still in the “Outbox” that means the recipients inbox is full. Hope that helps.
Aaron and other Members messaging system on the TIc170 forum
52' C-170B N2713D Ser #25255
Re: Aaron and other Members messaging system on the TIc170 f
Hi Doug thanks for the reminder. I think there is something else causing it to be in outbox. Maybe it is there until it is read? I was at 4/10 and your message came in ok. I replied and now the reply is in my outbox.
I believe that is correct. It’s also possible to go to your settings and create additional inboxes and change the number of msgs being stored.Aaron wrote:Hi Doug thanks for the reminder. I think there is something else causing it to be in outbox. Maybe it is there until it is read? I was at 4/10 and your message came in ok. I replied and now the reply is in my outbox.
Send messages remain in your outbox until they are read by the recipient. Once opened by the recipient, they will disappear from your outbox.
Messages sent to a full outbox will remain in queue in your outbox (because they can't be read) until the recipient removes messages from his inbox. As soon as there is room in the indox the messages waiting will fill the inbox.
You do not have to delete messages you want to keep from your inbox. You can create a Saved Messages folder and move them there. As an alternate you can change the behavior of your inbox so that if your box is full it will delete the oldest message though I don't know how desirable that would be. Click on Rules, folders and settings at the bottom of the left column to do any of this.
