flying without door
Moderators: gahorn, Karl Towle, Bruce Fenstermacher
flying without door
Postby new2cessna » Tue Apr 09, 2019 12:38 am
Hello lucky flyers, Anything we need to do differently or know about flying without the doors on a 48 170. One or both does it matter? Thanks Tim McCoy
new2cessna
Re: flying without door
Postby Bruce Fenstermacher » Tue Apr 09, 2019 1:45 am
Besides legality in the US?
Its' not legal to fly with any door removed unless you have a 337 or STC. These use to be available with a letter from the local FSDO if your aircraft was on a list found in FAR 105. That list has been removed. I understand now one must purchase an STC from the USPA for $200 ($100 for members) and that STC only covers certain aircraft of which the 170 is one. And then it was only the passenger door for sky diving. Once you get the STC, you must follow it and I'll bet it will tell you what door(s) you can remove and any other operating restrictions.
Email:
N7A '49 170A -More original than most making folks GREEN with envy
N42532 '45 J-3 Clipped Wing Cub
Postby swixtt » Tue Apr 09, 2019 4:23 pm
Jug knows....
swixtt
Postby gahorn » Tue Apr 09, 2019 10:57 pm
If you do this, be certain to recognize that ANY loose objects will fly around as projectiles including pencils, dust out of your carpet and anything in your shirt pocket. Also be aware that anyone who inadvertently unclasps a seat-belt is at risk. In addition, anything that leaves the cabin may strike the tail, disable the aircraft or render it uncontrollable (A tie down rope was once reported to be the reason elevator control was lost due to the flapping rope wrapped around the horiz-stab. Sounds suspicious but I wasn't there. Still...beware. Dust/Dirt from your carpet can enter your eyes and blind you. I do know about that as I once flew a 206 in a seeding operation that almost went badly.)
50th Anniversary of Flight Model. Winner-Best Original 170B, 100th Anniversary of Flight.
gahorn
Postby wabuchanan » Sun Apr 14, 2019 7:07 am
Heck, I can vouch for the danger of flying without doors personally. I've bloody well fallen out of doorless airplanes approximately 172 times...... 8O
1950 170A N5776C SN:19730
wabuchanan
Postby Joe Moilanen » Sun Apr 14, 2019 8:34 pm
wabuchanan wrote:Heck, I can vouch for the danger of flying without doors personally. I've bloody well fallen out of doorless airplanes approximately 172 times...... 8O
What a coincidence!! I have exactly 172 jumps also! Here is a link to my 171st jump. I jumped into my wedding reception 36 years ago. I jumped from 6,000' and planned on opening at 2,500'. At 2,500' I pulled and nothing happened...wouldn't even come out of the bag. I really didn't want to ride the reserve down because I had to land in a tight spot and needed the performance of my main chute. I hit the pack with my elbows as hard as i could and at 1,500' I finally gave up and pulled my reserve. The opening shock of the reserve was enough to make the main come out and it just hung down below me. I was then too low to make it back to the party and had to crash through the trees. Hope this link works...
https://www.youtube.com/watch?v=P_4ugQc ... Ymsow_OdeQ
Joe
4518C
Joe Moilanen
Postby gahorn » Mon Apr 15, 2019 6:12 pm
Fantastic Video! Glad to see you came out OK. (I always suspected our Assoc'n is made up mostly of nut cases.)
I must say in all honesty however,.... in my view, …. sky diving is a lot like setting your house on fire so you can play with a fire extinguisher.
gahorn
Postby daedaluscan » Tue Apr 16, 2019 12:33 am
Flame suit on. My understanding is that it is statistically safer to jump out of a light plane than to land in it. I have absolutely zero evidence to back this up.
Charlie
1956 170B C-GDRG #27019
daedaluscan
Postby sfarringer » Tue Apr 16, 2019 12:53 am
I don't believe that in general....
However, it may be true of some jump planes....
Ragwing S/N 18073
sfarringer
Postby Joe Moilanen » Tue Apr 16, 2019 1:03 am
gahorn wrote:Fantastic Video! Glad to see you came out OK. (I always suspected our Assoc'n is made up mostly of nut cases.)
You could be right George! People have always asked me why I would jump out of a perfectly good airplane, I guess they have never seen most jump planes...I started jumping before I started flying and that is what sold me on the 170. My first 100 or so jumps were out of a ragwing 170, four jumpers and a pilot and nobody ever gave consideration to the jumpers weights let alone the gear they had on their backs. Ran empty on fuel and "LEAN FORWARD FOR TAKEOFF!!" Good thing we were at sea level and had a 5,000' runway. The highest we'd go would be 7,200' which would give us a 30 second freefall.
Joe
Joe Moilanen
Postby cessna170bdriver » Tue Apr 16, 2019 1:04 pm
I don’t know how true it is, but I heard a story of a jumper who had never experienced a landing having to be restrained after the twin engine jump plane had an engine failure shortly after takeoff.
Postby canav8 » Tue Apr 16, 2019 11:42 pm
According to the STC holder of the door removal for the 170, it has some unique limitations. Bank angle restricted to 10 degrees and yaw angle is 15degrees.
52' C-170B N2713D Ser #25255
canav8
Return to The Pilot Lounge
Who is online
Users browsing this forum: Google [Bot] and 36 guests
