installing Cessna 175 tanks in my Cessna 170b
170tw
Post by 170tw »
Anyone out there every put Cessna 175 long range fuel tanks into there Cessna 170B giving you the benefit of having long range tanks? Might there be a STC available? Thanks for your help!
Mark
bagarre
Re: installing Cessna 175 tanks in my Cessna 170b
Post by bagarre »
There isn't an STC for it but it's been done several times on a field approval.
You need the tanks and a few other parts out of the 175 wings.
You also need electric fuel gauges as the 175 didnt have sight gauges.
Matt Lawson of Lawson Aviation up in Michigan (269) 521-6214 has gotten it approved.
There IS an STC held by DelAir to extend your existing tanks. You send your tanks to him, he welds on extensions and send you back the tanks, kit and paperwork. I think that's a $5k figure but not certain.
I went another route and just got the 175 wings approved for my 170. Know anyone selling a good set of 175 wings?
170tw
Post by 170tw »
Thanks for giving me some ideas. I know Matt. Forgot about the tank gauges being a issue.
bagarre
Post by bagarre »
I plan to use the ELECTRONICS INTERNATIONAL CGR-30 PRIMARY ENGINE MONITOR SYSTEM for my plane.
http://www.aircraftspruce.com/catalog/i ... -05345.php
But I also need the tach and manifold pressure and like the extra features.
Matt is a good guy. If you talk to him, Tell him David Ross said hello.
lowNslow
Post by lowNslow »
David, did you look into the Flint tanks, if so what did you think?
bagarre
Post by bagarre »
Only what I read on the forum.
I didn't like the complexity of extra filler necks and transfer pumps.
Same for the Javelin set up. More places to fill fuel and transfer pumps.
The long range tanks simplify things.
The DelAir long range tanks keep use of your sight gauges too.
lowNslow
Post by lowNslow »
Yeah except for the price the DelAir tanks seem like the way to go. Then again, nothing is cheap in aviation.
bagarre
Post by bagarre »
Yeah. DelAir is pricey but it's a bubble wrapped solution with no hoops to jump thru.
If you can get the long range tanks approved, I think that's the most cost effective route.
Keep in mind, most of the long range tank swaps I've heard about have not yielded much of an increase in usable fuel capacity on the placards.
You HAVE more fuel available but the legal limits might not change much for planning. It all depends on the guy approving the 337.
DelAir gets you 52 gallons usable.
flyboy122
Post by flyboy122 »
bagarre wrote:I plan to use the ELECTRONICS INTERNATIONAL CGR-30 PRIMARY ENGINE MONITOR SYSTEM for my plane.
It might be a bit more expensive, but you may want to look at JPI also. We got both units in and evaluated them and the JPI was hands down much higher quality.
DEM
The simplest way is to install a set of C-175 wings on a pre-approved 337.
Welcome back, Dick!
DaveF
Post by DaveF »
Here's part 1 of a four-part video series showing installation of the Del-Air long-range (+30 gallon) tank mod. I think there are two mods, the +30 "long range", which requires modification of two ribs, and a +15 gallon "extended" option, which modifies one rib.
Post by 170C »
Didn't find part IV, but the other 3 are quite interesting. Shows that there is a LOT of work to gain 15 gallons per side. It would be interesting to know what that project cost.
cfzxo
Post by cfzxo »
If anyone is interested in doing this mod PM me and I can give you a source for what is needed to do it.I salvaged the nose ribs from some 175 wings and the last time I looked the tanks and tank bay part of the wings are still in the surplus pile. I almost did the change myself but find the javeline tank setup easier to maintain and C of G management. bill.penner(at)gmail.com
lowNslow
Post by lowNslow »
170C wrote:Didn't find part IV, but the other 3 are quite interesting. Shows that there is a LOT of work to gain 15 gallons per side. It would be interesting to know what that project cost.
Frank, then you have to modify your bladder to go 6 hours without a taking a leak.
