Cowl supports
Mapleflt
Cowl supports
Post by Mapleflt »
To all,
I find myself wondering if anyone has ever "cooked up" a cowl support arm of any sort instead of just laying the open cowl over the top while checking oil levels and other associated pre-flight tasks ?
Cheers,
Mapleflt
Re: Cowl supports
You have a '52 and we assume the factory cowling. Always good to mention what you have cause there are two major cowl differences.
The factory '52 opens half the cowl at a time with the open cowl able to fold back on the closed half. The doors tend to be flimsy (bendy, not stiff) and make a great sail. I'm not telling you anything I'm sure. I've never seen anyone rig a support on these cowls or in fact even the later cowl. On the '52 and prior, usually the down wind cowl will be held open with the wind but the upwind cowl will be blown closed. If I need to keep the upwind cowl open I've wired it open with safety wire. But most times I just hold it. I'm thinking if you rigged a support, if you didn't reinforce the entire cowl door, the door would just bend at the point of the support.
Mapleflt
Re: Cowl supports
Post by Mapleflt »
Yes that's exactly my dilemma and its even more awkward for the 5-6 months when I'm on floats !!!
Re: Cowl supports
We should get in the phone at some point :)
I need to rebuild my cowling and I want to figure out a way to stiffen the barn doors.
My idea was to add formed stiffeners to hold it's shape as well as a way to hold is open vs flipping it over to the other side.
Re: Cowl supports
I could see why it would be a special pain while on floats. I'd think the first thing I'd try is a soft quick C-clamp or two like this:
On the upwind side to keep the cowl open against the wind open the door back against the center section. Clamp it there. One issue would be, will this C-clamp fixed arm fit between the cowl and the top inner baffle? I'd think toward the rear and not in the front'.
This 5" deep C-clamp available at Harbor Freight for $5 wouldn't be a one handed deal but it the fixed leg is thinner and the deeper C would allow the clamping action to have a deeper grip and better mechanical advantage:
I've not tried any of these clamps. Just offering an idea one might try that could be installed from one side of the AC. A 10 lb shot bag laid on the open cowl might be as effective in lighter winds.
Mapleflt
Re: Cowl supports
Post by Mapleflt »
I'm envisioning a 90 degree extrusion running full length of the cowl, below the horizontal cylinder baffles with a support arm that hinges off of it and positions into a strategically placed location
Re: Cowl supports
Im sure i can figure out something better than that
Mapleflt
Re: Cowl supports
Post by Mapleflt »
Let's give it a good, the 170 floats pilots of the world will bow down at your knees kind sir
Mapleflt
Re: Cowl supports
Post by Mapleflt »
Let's STC this and make our fortune !!!!
Re: Cowl supports
Mapleflt wrote:I'm envisioning a 90 degree extrusion running full length of the cowl, below the horizontal cylinder baffles with a support arm that hinges off of it and positions into a strategically placed location
I don't see your vision to understand your idea.
The C-clamp idea is simple. There are no modifications of the aircraft. Of course it may not work.
There might be something better and it could even be simple but it would be harder to be any more simple than a C-clamp and no other mods. Lots of times we tend to over complicate things. I fall pray to this all the time.
Of course the C-clamp would need to float since you will drop it in the water. And then you'll need a method, such as a fishing rod with a large hook to retrieve it. :?
Mapleflt
Re: Cowl supports
Post by Mapleflt »
I usually try to go swimming when I want to, not when I have to !!!!
Re: Cowl supports
Here's how Cessna did it on the L-19:
Figure 26 of the L-19 IPC shows the arm. Air Repair would be the folks to talk to about this.
The H-295 Helio Courier had similar upper cowl doors.
In the pictures you can make out the stiffeners which made the doors a lot less flimsy than the C-170 cowl. If I recall correctly they had a winged quarter-turn dzus faster to secure the end of the arm.
Re: Cowl supports
Gary strikes again.
IMO Gary, you have an uncanny ability to join a conversation with a fresh look how someone else (usually Cessna) engineered a thing-a-ma-bob to over come a situation. Many times you even have a SB to cover it so one doesn't have to squint so hard to make it legal.
Nice job Gary.
I'm still going to test my C-clamp idea after it warms up a bit here. I just have a passion for pursuing something till I've wasted more time and money than it would have taken to use the established mouse trap. Rube Goldberg is one of my heros. :roll:
Re: Cowl supports
Thanks Bruce! I'm with you on reinventing the wheel. There's a real sense of satisfaction on figuring out and completing a challenging project. Of course that comes after pulling my hair out in the process of getting to that often elusive satisfaction. :lol:
Now wouldn't a pair of Door Steward struts be the cat's meow to hold up the cowling doors? Why use a simple rod when you can use a pneumatic strut that weighs twice as much, will be flat in two years, and will require cowl door stiffeners to work? :wink: Here 'ya go!
If you didn't care about drilling holes in your cowl, for less than $4.00 and a couple of ounces, here's a "KISS" solution.
Put a hole at the front and the back of each door tangent to the point they touch when the doors are up. Add a doubler around each hole. Of course you now need to install steps on your boot cowl to reach up there ... augh. :lol:
Re: Cowl supports
n2582d wrote:Thanks Bruce! I'm with you on reinventing the wheel. There's a real sense of satisfaction on figuring out and completing a challenging project. Of course that comes after pulling my hair out in the process of getting to that often elusive satisfaction. :lol:
Gary, you missed the added requirement that the door be able to be held open when accessed from one side cause the airplane is on floats.
