Is there a reference for the pitot tube angle?
Looks like the paint shop bent the tubing on mine (It points more toward the sky than forward) and consequently, the ASI is a bit erratic at slow speeds/high angles of attack.
Correct angle for pitot tube?
Andrew Hochhaus
N3996V - 1948 170
N3996V - 1948 170
Re: Correct angle for pitot tube?
Fearless,
On page 16-9, figure 16-3 of the 100 series service manual you can find a template for the pitot tube contour.
Although it refers to the 172-175 models, it works well for the 170 also, I found it useful on my plane. Pm me your email and I can send you a copy if you need.
Wes
Wes
This template is for a 172/175 and is out ot the Cessna Service Manual '62 and Prior which of course is the same wing profile as a 170A and B. I think it's the best you'll do for a '48 which is not the same wing profile but I think you can swag it.
Make sure you print the PDF with no reduction or enlargement
Wow.....mine has AT LEAST 30 degrees more bend to it than that template!
Andrew Hochhaus
N3996V - 1948 170
N3996V - 1948 170
I bend mine down just enough so that water will not collect in it when the plane is on the ground.
