Window Hinge
Jr.CubBuilder
Window Hinge
Post by Jr.CubBuilder »
My window hinges are disintegrating. I thought I saw an article about replacing them, but all I'm finding is stuff about replacing the plexiglass. Has anybody else out there done this, and do you have any suggestions?
N2865C
Post by N2865C »
You can get new ones or replacement parts from Aircraft Spruce. http://www.aircraftspruce.com/catalog/a ... wlatch.php
There is a good exploded view of the latch in their paper catalog.
N2865C
Kyle Wolfe
Post by Kyle Wolfe »
Do a search under "window latch repairs" and you'll find some tips on what members have done.
I did the binder post fix to my pilot side. Will likely need to do the passenger side next year (since all I can do lately is fly on the right side - can't get my wife out of the left seat lately! :evil: )
Kyle
54 B N1932C
57 BMW Isetta
I believe Jr.Cubbuilder is talking about the hinges....not the latches.
The upper hinges are a pain in the B...side. Not much room to work, and will probably require you to remove the door to the workbench and get very handy with self-locking rivets. (Or find a very talented sheet metal person.)
This is not a common (as of yet) repair, but many of the 50-year old airplanes I've looked at are coming up on hinge replacement soon, including my right side. This is another excellent opportunity to take pics, write an article, and send it to headquarters@cessna170.org
Hinge stock can be cut to size to replace your worn hinges. The window side of the hinge stands up well as the frame is steel, in other words no pulled rivets. The door side may not fair as well if the hinge has been working for sometime. Upon removing the old hinge you may find elongation of the rivet holes. In that case you will have to oversize. That is unless that's already been done and now the holes are holes. Then a nut has to be dropped down through a hole cut in the top of the door.
Kyle Wolfe
Sorry Jrcubbuilder. Didn't read your question closely enough. Good luck with the project, and like gahorn says, keep us posted or write an article.
Kyle
54 B N1932C
57 BMW Isetta
Jr.CubBuilder
Yeah I'll let you guys know how it goes. I'll see if I can get a picture of them on here to, it's interesting how they are disintegrating and they are going at an ever increasing pace.
It'd be best to take pics/write an article for The 170 News...and you'd also qualify for the prize giveaway...if you can. Lots of members don't get on line and they'd miss your pics otherwise. (Do both.)
Jr.CubBuilder
Prize, What prize?
zero.one.victor
Post by zero.one.victor »
At the B0fD meetings, they draw names of literary contributors out of a hat for prizes. A year's dues or Assn merchandise is awarded to the winners, I got a logbook case a year or two ago.
zero.one.victor wrote:At the B0fD meetings, they draw names of literary contributors out of a hat for prizes. A year's dues or Assn merchandise is awarded to the winners, I got a logbook case a year or two ago.
Hey, Eric! Things are lookin' UP! With the new dues the prizes are finally WORTH SOMETHING! :lol:
Dave Clark
Post by Dave Clark »
When the door holes are worn out I've been able to, with very careful measuring and fitting, reverse the hinge orientation to drill fresh holes.
I've used soft pop rivets for fitting and then drilled out and used stainless pop rivets for final assembly which can easily be drilled out later. Yeah I know, not approved fasteners. Flame suit on.... :lol:
N92CP ("Clark's Plane")
1953 C-180
Brendalam0tt
Re: Window Hinge
Post by Brendalam0tt »
I'm ordering new hinges from univair today for left side. Any updates since this post started in 2005? Hoping there are pics / article somewhere that resulted. If not I'll take a stab at an article. Can't say enough how much I appreciate you guys on the forum!
Re: Window Hinge
I'm about to replace a cowl door and its hinge. Hinge stock is also available from Spruce https://www.aircraftspruce.com/catalog/ ... ohinge.php For the door I'll be using ms20001-3 hinge stock. I've done my window hinges some time ago not sure what stock is required for them, what will you be using?
DaveF
Re: Window Hinge
Post by DaveF »
Jim,
Pics and a write-up on cowl door replacement would be great!
