SAIB CE-19-13
Moderators: gahorn, Karl Towle, Bruce Fenstermacher
SAIB CE-19-13
Postby gahorn » Tue Jul 02, 2019 9:54 pm
The following was rec’d from FAA as a Special Airworthiness Information Bulletin (SAIB) regarding corrosion of flight control cable staged turnbuckles. These are common to airplanes such as ours. The problem is corrosion of those fittings that lead to fracture/failure and possible loss of control. If your flight control cables have not been replaced in the last 15 years FAA considers this a higher than normal risk. Download and read CE-19-13
CE-19-13.pdf
(259.5 KiB) Downloaded 408 times
50th Anniversary of Flight Model. Winner-Best Original 170B, 100th Anniversary of Flight.
gahorn
Return to The Hangar
Who is online
Users browsing this forum: Google [Bot] and 15 guests
