53 Cowl doors
Re: 53 Cowl doors
Good information Jim and a really nice job! Can't see from your photos any need to redo your door. However, if you find you are going to do so feel free to send me your first rebuild (minus latches). I think it would work wonders on 888A.
I know you will want to paint your cowl door to match that nice cowling, but that light shade of green might make your plane go a bit faster :mrgreen:
Frank
Re: 53 Cowl doors
170C wrote:Good information Jim and a really nice job! Can't see from your photos any need to redo your door. However, if you find you are going to do so feel free to send me your first rebuild (minus latches). I think it would work wonders on 888A.
Frank
Probably made him think the left wing was heavy and the P-factor increased. :twisted:
Re: 53 Cowl doors
Hard to get any respect around George :lol:
lowNslow
Re: 53 Cowl doors
Post by lowNslow »
Ordered some new H5000 - .064 latches and received them today and they look great. $12.00 each.
https://vod.ebay.com/vod/FetchOrderDeta ... noapp=true
ron74887
Re: 53 Cowl doors
Post by ron74887 »
Just a note: what I did was drill a hole at the top center of the door and add a screw plate under the cowling. you have to remove the screw to open the door but it will not open in flight or allow a lot of movement. Ron
President 86-88
jwlynnav
Re: 53 Cowl doors
Post by jwlynnav »
My pilot side door is doing same thing. It’s about to break the small piece of metal on aft latch as as the one in the pic that Jim repaired. I’m not handy as he (Jim) is working metal nor do I have the tools. Is there any repair advice?
Re: 53 Cowl doors
Missing the small piece over the tongue of the latch wouldn’t make me worry. If the door is a loose fit then a crack may develop as was the case for my pilots side door near the latch. I’d just try to delay further damage by using silicon where the latches contact the cowl to reduce vibration damage.
DaveF
Re: 53 Cowl doors
Post by DaveF »
I've seen new doors fabricated without the troublesome little strip. Doesn't look as good as the original, but it works.
jwlynnav
Re: 53 Cowl doors
Post by jwlynnav »
Thanks I appreciate the response
DaveF
Re: 53 Cowl doors
Post by DaveF »
The small cotter pin prevents the latch from opening too far and breaking the little strip.
DaveF
Re: 53 Cowl doors
Post by DaveF »
Here’s my new door. I still have some trimming and bending to make it fit just right.
Re: 53 Cowl doors
Nice Dave,
As they say its easier to take the metal off than put it back on. Perfect with these doors can take some time.
DaveF
Re: 53 Cowl doors
Post by DaveF »
Not as nice as yours, Jim, but I’m reasonably satisfied. Took three attempts to get it right, or at least acceptable.
DaveF
Re: 53 Cowl doors
Post by DaveF »
Door number two!
Re: 53 Cowl doors
I’d say better, nice work on the latch cut-outs.
