Vacuum Air Filter
Vacuum Air Filter
Just hooked up my Vacuum system again after having my DG overhauled. I only have one instrument on the vacuum system. Does anyone make a small air filter that can be attached directly to the back of the air intake on the DG?
1952 170B
N8180A s/n 25032
N8180A s/n 25032
Re: Vacuum Air Filter
The AN gyros had pancake/flat filters incorporated on their cases... but they aren't particularly "sturdy" in the sense they won't hold much dirt if you're in a dusty environ. It should be easy to use a short piece of vacuum hose with a "nipple" and attach a canister filter such as the Rapco Model RA2J4-4
http://www.aircraftspruce.com/catalog/i ... key=280803
Nipple: http://www.aircraftspruce.com/catalog/h ... ckkey=5344
And of course as you will only have one line you must plug the unused line on the filter George mentioned.
Thanks guys. I have the Rapco filter. I was just wondering if anyone has ever seen something smaller that could screw in where the nipple goes. I imagined something similar to this
https://www.grainger.com/product/SPEEDA ... Vent-1EJT6
1952 170B
N8180A s/n 25032
N8180A s/n 25032
Mike, As George said each instrument had it's own internal filter. Amazingly, although the prices have increased a bit, these filters are still available online. Here's a SNL with some part numbers:
Edit:
I'm curious which Rapco filter you are using as Cessna mounted these differently over the years. As you have a DG and an attitude indicator it seems that the two port filter would work best for your application. Personally I'd stick with the Rapco filter as I think it would filter better than an inline filter like you pictured. It'd be a lot easier to replace as well.Edit:
In an earlier post with a picture of your panel you had an attitude indicator. Did you remove that?I only have one instrument on the vacuum system
Your little screen filter looks like a Cummins fuel system filter for the fuel pump aneroid intake system [1/8" pipe].
John Hess
Past President 2018-2021
President 2016-2018, TIC170A
Director 2005-2014, TIC170A
N3833V Flying for Fun
'67 XLH 900 Harley Sportster
K3KNT
K3KNT
The small metallic filter depicted above will not have much media-capacity for an air filter. That sort of filter is designed to catch large particles in a suction "pick-up" tube or such.... it cannot contain much dust/dirt which is what you need... if you want that gyro to last very long. I recommend you use an ordinary gyro filter such as suggested previously.
Thanks George. I did install my Rapco filter back on there. Thanks everyone!
1952 170B
N8180A s/n 25032
N8180A s/n 25032
