First annual
vaflyer
First annual
Post by vaflyer »
I'm getting ready to do my first annual on my C-170B, serial #20418. I'm looking for advice on common problems and areas that require extra scrutiny, etc. I have a F&M filter on the C-145, not sure if there are any special items to look at on this filter assembly. Also 180 gear, scott tailwheel. I have a copy of the Cessna series 100 service manual dated 1 FEB 1962. What and how do I get the current manual? Please excuse my ignorance!
Re: First annual
The Cessna 100 Series Service Manual, 1962 and Prior is the current manual, although the latest revision may be obtained from Cessna Publications. (Unlikely to have much more useful info than your present copy of the manual...but it's technically more "legal".)
Corrosion, Landing gear attach, wing attach, rudder cables in aft of fuselage, rudder pedals wear/looseness, stabilizer spars and bulkhead for cracks, and all the rest of the 100 hour items. PAPERWORK on all installed equipment and modifications. Just a few of the many items others will also likely mention.
Re: First annual
I would look at your log books very carefully and then have a look and identify all mods and STC,s . Some mods and STC,s are written up correctly but over time and different owners , they are removed or changed . Some PMA parts are authorized for some models and not others so a careful scrutiny of the aircraft and log books has to be done . Have a look,at all the AD,s that are applicable also. Plus Cessna releases "Service Letters" and some times these are incorporated but have they been done correctly and completed. The FAA web site has a lot of good information about your model and legal STC,s .
Ryan Smith
Re: First annual
Post by Ryan Smith »
He's got Greg Hren's 170. I feel confident that the mods were done properly.
Check your main tailwheel leaf spring, tailwheel bracket, MLG bolts (if they can be torqued, they have stretched and should be replaced) as well as the gear leg shims and extrusions.
vaflyer
Re: First annual
Post by vaflyer »
Thanks and keep them coming!!
Re: First annual
Engine mount to firewall rubber bushings, condition of various ground straps in engine compartment.
