Adding a Saved PM (or additional) Folder to your PM system
A place for consolidated forum rules, instructions, announcements and information.
Moderators: gahorn, Karl Towle, Bruce Fenstermacher
Forum rules
This area is read-only. Only Administrators and Moderators can post here. Please use a private message to the Moderators for questions or comments.
Postby Bruce Fenstermacher » Sat Mar 11, 2017 4:28 pm
I assume if your looking at this you already know how to get to the Personal Message (PM) area of the forum software by clicking on User Control Panel in the light blue bar, left towards the top of the Board Index page. Here is what you will see.
The standard PM folders are Inbox, Outbox and Sent Messages. These folders can not be deleted, duplicated or their behaviour changed. But you can add as many new folders as you would like, each capable of holding 10 messages and each having a different behavior when full.
To do this click on Rules, folders and settings and this is what you will see.
This is a multi purpose window. From here we can add a rule to an existing folder or add a new folder or change the behavior of any folder other than the standard folders, that we already added. We are interested in Add a Folder.
Enter a name such as Saved PMs in the blank and click add.
This will create the folder and the multi purpose window will change allow more options.
At this point you might want to change the default behavior of the folder you just created. To do this click on the folder you want to change then click Rules, folders and settings, and the window will switch to the multi purpose window for that folder.
Looking at If the Folder is full and decide if you want to change the selected behavior. Moving it to the Inbox does not make sense if this is your over flow box so the only logical change might be to simply not accept new messages when full. Click Change after you select any change to make the change.
I do not believe there is a limit to how many extra folders you can create but there might be. So in theory you could create say 3 folders and set each one to overflow into the next thus saving 30 messages.
Email:
N7A '49 170A -More original than most making folks GREEN with envy
N42532 '45 J-3 Clipped Wing Cub
Return to Forum Rules, Instructions, Announcements and Information
Who is online
Users browsing this forum: No registered users and 1 guest
